It is currently Fri Aug 22, 2025 9:36 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri May 16, 2014 4:45 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
RusRob wrote:
I have been looking at the Jet 16-32 and thought that is the one I wanted to buy.
However after checking out the link for the Supermax 19-38 I am considering that instead, mainly because of the ability to handle 4" thickness.
I am curious if anyone has any direct experience with both of these and how they compare. I have read the spec's so I know the difference between them but I am wondering about quality and how they actually work in a shop setting.
Bob
Hey Bob - I haven't used both but I looked over the Jet 16-32 very closely at the local Woodcraft store while I was shopping for a drum sander. It seems like a child's toy compared to the Supermax 19-38. For a few hundred extra dollars you get a much more robust machine. The Supermax is built with thicker cast iron, and even the drum lid is thick sheet metal (the Jet is plastic!), and of course, it's three inches wider. Everything about it is top professional quality.
These users thanked the author Goodin for the post: RusRob (Fri May 23, 2014 10:16 pm)
PostPosted: Fri May 16, 2014 5:52 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
I know its not as convenient as buying one but you could always get another motor, couple rollers, speed control, and conveyor belt and just rig it up to your existing design. idunno
PostPosted: Sat May 17, 2014 4:15 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
You know Doug, you can have both... :-)
PostPosted: Sat May 17, 2014 5:30 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
....and the golf clubs as well!
Alex
PostPosted: Sat May 17, 2014 6:45 pm
First name: Michiyuki
Last Name: Kubo
State:
Country: Österreich
I guess the question now is, what kind of car do you have ? :)
久保
美智え
PostPosted: Sun May 18, 2014 8:08 am
First name: Rob
City: Cochrane
State: Alberta
These users thanked the author Robbie_McD for the post: Michiyuki Kubo (Sun May 18, 2014 1:26 pm)
PostPosted: Sun May 18, 2014 8:33 am
First name: Larry
Last Name: Hawes
Rod True wrote:
Hey Doug,
Why not look at the open ended wide belt sander general makes also?. They are right in the same price range as the drum and will give a far superior finish as well as belt life will be much longer. This is what I'd be getting if I had the cash.
Curious about the specs of this sander. How would this be OK for guitar tops wider than 15" and thinner than 1/4"? Are those just recommended specs and one can sand a 16" wide top somehow??
Maximum sanding width 15” (380 mm) / *30” (*IN 2 PASSES)
Minimum sanding thickness 1/4” (6 mm)
Answering my own question - maybe - you use a couple passes for wider stock? The 1/4" must surely be a suggestion only and not a true minimum?
Thank You and Best To All
PostPosted: Sun May 18, 2014 8:35 am
First name: Larry
Last Name: Hawes
I've been intrigued by this double roller drum sander. Haven't read/heard anything but looks interesting.
http://www.grizzly.com/products/24-Drum-Sander/G1066R
PostPosted: Sun May 18, 2014 9:10 am
If you like doing burn-outs.... with some self-stick 80 on your rear tire you could add the functionality of a drum sander to your bike justifying keeping it. Problem is finding someone in the neighborhood that you dislike enough to talk into holding the wood in place as you do the burn-out.... :D
Seriously lots of great sanders out here. My Performax 10-20 Plus will be 10 years old next year and it has been flawless for me with lots of stuff passed through it over the years. Recently when we unearthed the stash of 50 year old German tops it got a real workout and never misses a beat.
True it requires two passes for joined tops and backs but is not having to do that extra pass worth the price of a single pass sized machine to you? It's also true at least with mine that the feed belt keeps trying to have an affair with the motor but I just let em do what they are going to do anyway and never had any issues still using the original feed belt.
Some years back on the OLF a number of 10 - 20 users upgraded to a bigger sander and then expressed some regret because they thought that the 10 - 20 held tighter tolerances.
For me tools are a means to an end with my real interest being the guitars that I can build or fix. If a tool works for this, what I intend it to do, it's good enough. If it does not do a great job off it goes. Plain and simple.
PostPosted: Sun May 18, 2014 6:28 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
A sander may be spec'd to 1/4", but u can use a sacrificial board to go thinner. My drum sander will go pretty thin, but I don't like the drum being that close to the conveyor belt, so I lift the piece up with a board.
PostPosted: Thu May 22, 2014 7:48 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
So I found a sander...Performax 22-44. $800 in brand new condition. I'd say I did pretty well ... and that would be grossly understated. I just need to find a way to get it as it is a 12 hour drive from home in Northern Alberta.
Doug
PostPosted: Thu May 22, 2014 10:38 am
Does it have a mobile base?
PostPosted: Thu May 22, 2014 11:43 am
First name: Alex
Last Name: Kleon
City: Whitby
Thats a nice find, Doug. Could shipping it be more cost/time effective? I found a shaper on Kijjijji, great condition and price, but it was in Thunder Bay. :(
Alex
PostPosted: Thu May 22, 2014 11:45 am
Ha ha, just tie it to the trailer hitch and you're good to go!
PostPosted: Thu May 22, 2014 12:04 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Alex
With shipping total cost: $1000. I'm a very happy camper.
Doug
These users thanked the author Doug Balzer for the post: ZekeM (Thu May 22, 2014 1:32 pm)
PostPosted: Thu May 22, 2014 1:32 pm
First name: Zeke
Last Name: McKee
Wish I coulda found a deal like that when I bought my little 10-20. I spent nearly as much as you and mine is tiny.
PostPosted: Thu May 22, 2014 3:31 pm
First name: Alex
Last Name: Kleon
City: Whitby
Last year there was someone in Toronto selling two 22/44's on Kijjijji, both brand new, $900 each.
I was tempted, but I figured at that price they had fallen off the back of a truck, and I don't like that sort of deal.
$1000 delivered is the kind of deal that would let me sleep at night! What Kind of dust collection do you have, Doug? I would think a 2hp unit would do a pretty good job.
Alex
PostPosted: Thu May 22, 2014 3:56 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Alex
Alex, I've got a four-bag, 3hp 220v unit. I'm good to go.
Doug
PostPosted: Fri May 23, 2014 10:29 pm
Last Name: Russell
State: Michigan USA
Bob
Yea I just looked over the Supermax and you are right it is built a lot better than the Jet. The Supermax seemed more like a pro tool where the Jet appears to be for a hobbiest.. I think the extra cash would be well spent.
Here is a blast from the past... I just dug out my scooter from the bowls of the lower garage I am turning into my new shop. I have an interested buyer for it so I pulled it out and cleaned it up a bit. I bought it when it was only 6 months old back in 1972. Did all the work on it myself and drove it up until about 20 years ago. About once a year I squirt a shot of oil in the cylinder so she wouldn't freeze up. Its been sitting collecting dust and rust all this time so it is time to say goodbye to it. The cash I get from it will go toward that new Supermax [:Y:] .
Cheers,
Bob
PostPosted: Sat May 24, 2014 12:27 am
Last Name: Curtis
City: Mangrove Mountain
State: N.S.W
Zip/Postal Code: 2250
Its all a front Doug's going to buy a 1098 thumper.
PostPosted: Sat May 24, 2014 8:25 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
I don't even know what that is! Pray do tell.
Doug
PostPosted: Mon May 26, 2014 10:29 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
I had to build my drum sander. Yes I have to push it through and get it on the other side. I have great dust control. I probably use it more then any tool in the shop. But I built it for less then 500$. Paying a friend to do most if the work because of my health. Has a 3 hp 220 volt motor. Does a great job. Couldn't afford anything else. But you hafta have one don't ya?
PostPosted: Tue May 27, 2014 9:17 am
Last Name: Lee
Country: Wales U.K.
Doug, I am curious. It's probably just an American English versus U.K. English thing but when does a motorbike become a scooter or vice versa? You scooter would be a motorbike or a chopper over here.
PostPosted: Tue May 27, 2014 9:34 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
I'm Canadian so I can't speak for my US friends, but generally a scooter has a low cc engine, I.e. 50cc. My ride has 1000cc. She ain't no scooter.
Doug
PostPosted: Tue May 27, 2014 10:12 am
First name: Zeke
Last Name: McKee
Pretty much. Also a motorcycle you straddle whereas a scooter you sort of sit on with your feet in front of you. If that makes any sense.
